Simatic net ie softnet-s7 lean
IE Softnet is a comms software for a regular ethernet card in a PC.
Typically for providing an OPC Server.
Other uses are in combination with WinAC, WinCC and/or WinCC Flexible.
LEAN is limited to max 8 connections.
BASIS is limited to max 16 connections.
Hello everyone! We have a computer running on Windows XP 32 bits SP3 where Simatic Net Softnet IE 2008 Lean is installed, with C++ (VC6.0 and...
1,410
I installed PB softnet S7 on windows NT4 SPa how can i configure this program ? regrads M.del
4,685
I don't know if this is the right place for the subject at least I'll try. The company has one of the oldest computers that is a master Windows...
755
I had a system running WinCC v7.0 SP3 and SIMATIC Net V8.1 SP2. The WinCC Runtime project was reading symbolic tags (e.g. D435.HMIVars.Start) from...
1,698
My problem is that I can not approach variables from OPC Scout 10. I can see Data blocks but not variables. I'm using TIA portal v14, SImatic...
2,897
