simatic net v6.2 problem installation on xp sp1
RAJEEVA
Mar 2006
mysore
i have problem reinstalling simatic net v6.2 on xp sp1. Have checked everything as per manaula but still unable. some one has similar experience help/
This is what I replied to rajeevas PM:
JesperMP said:
hello rajeeva,
You can manually deinstall all Siemens components. There is a FAQ on Siemens support site about how to do this. Search for "complete deinstallation".
By the way, rajeeva said in the PM that the deinstallation of WINACE started, and then the application stopped.
There is also an "install.txt" file generated somewhere - it has proved invaluable in the past for fault finding failed dimatic installations - search for it - I'm sure it will help . Simple things like the computer name being in lower case can cause the installation of WinCCFlex to fall over (yes I know it doesn't make sense , but it is in the KB) .
Hi all, I am trying to load a program to a simatic panel I have set up the ethernet communication so that both my pg and my panel have the...
2,392
After installing simatic net ...my simatic manager ---> new project wizard is not opening .....it just not giving any action after clicking Wats...
6,489
I am using tht module and facing a strange problem. When i turn on the PLC and load the logic the ACTIVE LED of the 2752 keep blinking even after...
6,009
I don't know if this is the right place for the subject at least I'll try. The company has one of the oldest computers that is a master Windows...
748
I had a system running WinCC v7.0 SP3 and SIMATIC Net V8.1 SP2. The WinCC Runtime project was reading symbolic tags (e.g. D435.HMIVars.Start) from...
1,693
