Simatic ProTool/Lite
Mylo
Aug 2002
Dublin
135
Hello All,
Would anyone know a simple/Quick method of creating "Tags" in Siemens Simatic ProTool/Lite. I seem to be only able to create Tags by selecting each, one at a time. This is quite a labour intensive exersise as I cannot select the structures only the elements. Obviously this is to ensure that I can place Limit values on each Tag. However I have a couple of hundred to do and its a tiny bit cumbersome.
The method I use at present:
>RightClick - Tag insert
Open tree to Structure
>Click element
>Apply
>ok
-Limit Values.
Any ideas?? can I import Symbols automatically?
Cheers,
Mylo
Yes you can import symbols.You just have to go to the Hardware Configuration in Step 7.And then you assign the simoblic names to all the inputs,outputs...etc and then click add symbols.
Now in Protool when you define the tags just click on the with symbols check box and your simbols will appear.
I hope this helps and that I'm not way off on my answer :)
Hey NoName,
Sorry reword the query,
""can I import Symbols automatically?"" should have read " Can I Import the Data as Structures into Tags?"
I can import symbols easily as you say however its the Tag generation I was hoping to find easier. i.e by selecting the structures themselves
Cheers for the reply though
THanks Jesper,
I'll give Siemens a Call and ask them to re-write Protool Version,,
well its worth a try isn't it !!! :D :D :D
Mylo
Does anyone know where I can download the Simatic ProTool software? Thanks.
1,526
I am in the process of moving software from one laptop to another. So far everything is going OK except I can't find the Siemens Simatic...
1,602
Hello All I need to get the Backup of TP170A for this I tried PROTOOL and PROSAVE and configured communication parameters via COM1 Gives Error...
3,056
Hi all, I am using Protool 6.0 with Step 7 V5.3 and Simatic S7 300. The problem is that in Runtime mode when I push switch button to ON position...
2,703
hi every body i am working on SIMATIC Protool, i want to ask how to make a pop up window for an object (pump for example) so when i press the...
3,894
