simatic s7 online
indra
Apr 2005
indonesia
161
Hi, guys,
I have SIMATIC S7 software STEP7 Ver 5.3 with SIMATIC S7 PC ADAPTER USB ( 6ES7 072-0CB20-0XA0 ). At the moment I have a proble with ONLINE and UPLOAD the PLC program, type of PLC is I/O distribution system ET200S with connection to SINUMERIK 840D.
Please anyone knows how to make ONLINE and UPLOAD the existing PLC program because when I run the STEP 7, there are some setting for Set PG/PC interface. If I use this USB adapter ( 6ES7 972-0CB20-0XA0 ), do I have to go OPTIONS, click on SET PG/PC INTERFACE, then on PC ADAPTER ( MPI ) there are : STATION PARAMETER ( address and timeout ) & NETWORK PARAMETER ( transmission rate and highest station address ). Please inform me what VALUE that I have to put on these parameter ?
Regards,
INDRA
Hi Indra,
I've only used the default settings so far. Just don't set the address to '2', because that's the default factory setting for the PLC. More important is to see if the local connection is set to 'USB'.
Kind regards,
Got a VIPA 315-2AG23 that i try to go online with but can't seem to make it work through a network. I can go online if i'm plugged directly in the...
274
Hi , I am working on Siemens CPU 315-2DP(6es7315-2af03-0ab0) while working online i try to modify bool value memory address M33.3,M34.0 but it is...
2,329
Hello Experts, How can i update my offline Data Block to the Online Datablock without removing the offline comments? When i go online with the...
3,590
Simatic S7-400 password online (RAM) I have PLC S7-400 with a password. Actual project step7 not have, but have old backup project. All programm...
1,811
I need some one to help me to be online connect with Simatic S5 95U
1,427
