Simatic software declaration table
SHYAMAL
Aug 2007
DHAKA, BANGLADESH
53
Dear friends,
In variable declaration table of a function block there are five declaration types – in, out, inout, stat and temp. But, I’m not clear about the utilities of stat declaration type. Could anybody please make it clear to me with some examples?
Thanks.
Shyamal
Static data contains named variables that are stored in the instance data block associated with the function block. These variables are retained from scan to scan (unlike temps) so you use them for edge detection, counting and the like. You can also declare other function blocks in the stat area - this means you can have a host of function blocks all sharing the same instance data block.
Hi LD[AR2,P#0.0]
Just a question
Are you a paid member of PLCS.net, under which you have the facility of receiving the SMS on your mobile the moment somebody ask any question of your interest? And under this facility you also need not log on to answer any question??
Asking because you jump on s7 questions like tiger and is always offline.
******No offence intended******Just for fun***
Good Evening , It has been several years since I used Siemens Software . I’m looking to purchase the software for a Siemens Simatic S7...
503
I have new Siemens PLC / Simatic S7-1200 Need software download to use the PLC Please advise Thanks Wally
2,250
645
Hi All, Please let me know the availability of the Siemens SIMATIC 6.1 software. Basically, I have one SCADA Backup fo which customer has told...
1,700
Hi there, I have been using CxOne and Sysmac studio, and have a small job coming up using TIA portal V12. I was wondering if you could outline...
2,797
