simens small size plc
Siemens have many PLC's within their range.
The older S5 and the newer S7.
Within each range there are several models.
The small S7 range is called S7-200
The S5 had S5-90;95 and 100 models.
Stick with the S7-200 models, they are newer.
Beware: stepping up from S7-200 to S7-300/400 is not easy. The S7-200 is in fact a descendant from the TI PLC's, whereas the S7-300/400 are "real" Siemens PLC's.
The S5-90/95/100 families are also real Siemens PLC's, but these are out-of-date.
So, stick to the suggestion by Moggie and count on having to learn again when stepping up to the bigger S7's.
So I am working on a machine where the PC has died. The PC was running Windows XP, Protool RT, Step7 V5.3, SimoComU and other software. The...
2,455
Hi folks, I'm working on a glass jar packing machine and trying to figure out how this STL code works. Most of the code is in ladder or FBD. But...
25
9,221
Hello All, I have a system of 2 PLCs Siemens CPU 315 - 2PN/DP (with a program Simatic S7 V5.5) and PC station runs Siemens OPC server Simatic net...
20
7,347
hi.. how to sent the data using maestro gsm modem 100 to PLC. i try use hyperterminal to the hand phone and it work..when i use PLC it not...
1,194
High I am fairly new on siemens S7 and have a breakdown with a machine that is referencing a tag called DB50.DBB256 how can I search the whole...
1,664
