Simocode Star Delta switchover problem.
swapnil.naik
Mar 2013
Thane
45
We are using Simocode (Motor Management System) and facing an issue while running a STAR-DELTA Starter
Attached are the drawings for your reference along with the simocode program
We have kept Max Star to Delta changeover time as 10sec
When we check the feeder without Load (No motor load connected), The changeover time is observed as 10 sec
But when we connect actual motor and start the feeder
The changeover from Star to Delta is not 10sec but it happens at around 2 to 2.5 sec
Is the changeover current dependent?
How can we make it to work with only timer (10sec)
Thanking you in advance for your help and support
There is no attachment
I am not familiar with simocode
you said MAX start time setting
I would say that 2~2.5 secs is less than that.
Motor start will always depend on load, so, if you were to set a timer to 10secs the motor would remain in Star until the timer times out.
I would think if there is a current input to the simcode - YES
it would sense the current
Good afternoon all. I would like to be able to simulate sending and receiving specific bits between my Simocode pro V EIP module and the...
1,376
Hi, I'm looking for the eds file for a simocode module "BASIC UNIT SIMOCODE PRO V MR". So far, I can only find the eds file for the pro V EIP...
1,742
:banghead::banghead: Dear all, we have a SIMOCODE that is used to turn on/off some important pumps in the factory. Communication is via...
2,273
Dears Once again need your support. I am starting on a simocode.After factory reset, I am trying to make some changes or reconfiguring the...
3,170
Hi guys, We have a conveyor at work that had a flight break off and did damage to the conveyor. We use Drag Conveyors......I was asked if a...
1,649
