Simodrive 611 Standby Power
maniec
Sep 2006
South Africa
29
infoI have a Simodrive 611 installed in a machine with a S7-300 PLC.
We want to connect a single phase UPS to the plc so that the process values can continue to be processed in case of a power failure. Currently we are getting an communication error from the Simodrive.
The 24VDC PSU and 230VAC is still be available in the panel.
When the power is restored the machine can then continue from the point it stopped.
Can the Simodrive be supplied wit external power (ie not through the U V W connections) so that it can still process data, communicate with the plc, even though a fault (mains failure) will be generated. Currently we are getting an communication error from the Simodrive.
The whole idea is to be able to enable the machine to continue, with operator intervention, from where it was stopped.
Hi,I have been tasked to upgrade the PLC of a Blowing machine (Gefran) to compactlogix,the machine has Simodrive 611 with CAN bus. My thought is...
1,430
Hi everyone...Can someone give me an idea how to solve the below problem: 1- I'm using a siemens simodrive 611 in one of our machine, 1 of the...
2,507
Dear sir, I have SIMODRIVE 611 universal 6SN1118 2Axes Resolver 611U and I have servo motor with incremental encoder. I need modify the drive to...
1,597
Hey guys im getting some faults with our simodrive 611 and cant seem to find the fault codes anywhere was wondering if anybody could help. The...
3,499
i have a cnc lathe which used simodrive 611 from siemens , we have an orignal card came with the machine about more than 12 years which is...
3,160
