Simodrive programming help
Panda78
Sep 2014
IL
Hello
we recently purchased a used machine (about 12 years old) that has a motor controlled by a Simodrive 611.
There are 2 units:
U/E MODULE: 6SN1145-1AA01-0AA1
LT MODULE: 6SN1123-1AA00-0DA1
How do i get online and upload the settings, in case i need to replace the drive?
I found the software on the Siemens website (SimoComu), it seems you can connect to the drive using a serial cable, but the only port that i see on those modules that looks like a serial port is the one where the motor encoder is connected, so i doubt it is that one.
Thanks in advance
I didn't look up your part numbers but does the front have a display and have an up and down button?
Or just pots on the front?
we need to replace the below Simodrive infeed module by a new line module from Sinamics family. 1. is this possible? 2. any special...
3,118
Hi,I have been tasked to upgrade the PLC of a Blowing machine (Gefran) to compactlogix,the machine has Simodrive 611 with CAN bus. My thought is...
1,430
Hi everyone...Can someone give me an idea how to solve the below problem: 1- I'm using a siemens simodrive 611 in one of our machine, 1 of the...
2,507
I know that this question might be a little dated but I am hoping someone here may know. We are purchasing a used machine and it has a rack of...
1,270
Dear sir, I have SIMODRIVE 611 universal 6SN1118 2Axes Resolver 611U and I have servo motor with incremental encoder. I need modify the drive to...
1,597
