Simoreg DC Drive
Altaf Belim
Jan 2004
karachi
27
Hi to All
I have a problem in simoreg dc drive,there is a fault code F067 convertor cooling fault as per fault diagonisis there are three things.
1.Heatsink temp> Impermissible heatsink temperature.i002 measured heatsink temperature (16384...100 degree centigrade),i003measured ADC value.
2.Heatsink temperature.
3.Convertor fan defective.
I have checked the heatsink temperature which is 34 cenitgrade degree,its temperature sensor and its cooling fan all there things are ok. One thing which I don't understand is that heatsink temperature > Impermissible heatsink temperature i002 measured heatsink temperature. Is there any parameter in which we mentioned the heatsink temp.
Please help me in this regard how to rectify this fault.
Regards
Altaf Belim
tell us more how it is sensing the heat sink temperature. The heat sink is OK at 34C but what is the sensor ie thermocouple or whatever telling the controller and is it telling the truth ie accurate?
Dan Bentler
Hello people This is my very first post in plctalk, so im sorry if my question is out of place. We're using a simoreg dc drive and currently is...
1,540
Dears kindly need support to replace old SimoReg DC master Siemens Drive and upgrade to sinamics 6RA8081-6DV62-0AA0 series communication is...
2,498
Dears i need help to enable and run drive manual using terminal block only test it FWD and REV
1,613
Is it possible to interface an encoder of open collector output to a SIMOREG 6RA70 drive? Any suggestion / help will be appreciated. Shyamal
1,527
Hi everybody I have an special simoreg 6ra70 dc drive, its current is very huge(2600 A, this rating is not on the manual, so i think it is...
2,520
