Simoreg drive parameters
krome
Jan 2009
michigan
31
I am trying to set up a simoreg dc master drive to receive and send control words using profibus. If I want to send a parameter to the plc I use parameter U734 (CB/TB sel tmsm1), in there if I want to send for example the speed set point which is in K0011(not sure if it is) I would go to index 5 and look up K0011 to add it there. IS that all I have to do for it to send it on the drive part?
Also I am not sure how to set up the parameter when the PLC sends the control words. My understanding is the words are store in Z3001 thru Z30016 how would I use that information if I need to send it to Z0012 for example?
I change P918 to 4 for it address node
Thanks for your help I really appreciated
Hello people This is my very first post in plctalk, so im sorry if my question is out of place. We're using a simoreg dc drive and currently is...
1,540
Dears kindly need support to replace old SimoReg DC master Siemens Drive and upgrade to sinamics 6RA8081-6DV62-0AA0 series communication is...
2,496
Dears i need help to enable and run drive manual using terminal block only test it FWD and REV
1,613
Is it possible to interface an encoder of open collector output to a SIMOREG 6RA70 drive? Any suggestion / help will be appreciated. Shyamal
1,527
Hi everybody I have an special simoreg 6ra70 dc drive, its current is very huge(2600 A, this rating is not on the manual, so i think it is...
2,519
