simple ladder program for elevator
gcpatil4
Nov 2015
pune
I want simple logic for elevator .
m going to use four pushbuttons for four levels and four proximity sensors . that's all.
m trying this in ab plc . but m not getting it properly. plz help. I have attached what I have tried. what are the errors in it.
What does it do, that you want it to do? (what works so far?)
What does it do, that you don't want it to do? (bugs?)
What does it not do, that you do want it to do?
whenever I press any pushbutton I want motor to run in forward or reverse direction (MF or Mr) unless proxy sensor of that floor is on.
but in my program motor is not getting latched when I press any pb.
I am new to this. I have basic info of plc and ladder programming. therefore m trying to solve such questions to increase my logic solving capability. :(
Hello, I´m having a problem trying to program in Ladder. An output should be trigged by two possible contacts. Take a look on the printscreen...
151
I have a program that does a 7 second "scan" sensor calibration routine whenever a setting (setting is called assistance level or "AL" and ranges...
219
Hi all, I have a simple question that I have overcomplicated and gotten stuck on. I have a variable, we can call it "light" that I need to stay...
331
I need help answering a problem regarding the design a ladder diagram for a security light control. The question states when a sensor is...
2,062
Hello. After doing a couple quick searches I couldn't find anything concrete on what I should use for a simple ladder drawing program. Since all...
1,797
