simple logic with 2 motors, logo, vipa 100, siemens s7-224 ... ?
I have used plenty Logos and S7-224 and 226 PLC's. Also often S7-300. Personally I think the Logo is more reliable than S7-200 but obviously limited. I would try program the project in Logo software - you can simulate everything without any hardware. If it works - don't give it up as a bad idea. Obviously S7-300 much better but expensive. If you go S7-200, don't touch anything less than a 224.
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
169
I have an application that needs 20 inputs and 20 outputs with only 10 XNOR and 10 NAND blocks. I could do it with relays, but this could end up...
5,171
Could someone explain why on the first screen the highlighted Output_1 is not energized while on the other it is? My understanding would be that...
21
5,964
Hi just trying out some alarming logic to work with siemens microwin s7-200 can anyone help me convert this simple ab logic to siemens microwin...
2,005
I am new to PLC programming and recently purchased a demo unit for a WAGO 750-881. I am trying to do a simple test in ladder logic that does the...
2,285
