Simple Pneumatic question
LoganB
Apr 2017
Michigan
607
Good afternoon!
I was given my first assignment dealing with pneumatics and am sort of going through a crash course (taught by google) in the symbols and their meanings. One that I'm having some trouble finding (and not entirely sure if it's even valid) is attached.
This is an electronically activated (left side end piece) solenoid with a spring return (right side end piece), but I'm unsure of what the line extending from the end of the triangle on the right side piece towards the center means. Can anyone enlighten me?
Also, I've only been able to find different examples of entire valves, I haven't had any luck locating a document that breaks down the different symbols and shows all the variations and what they mean. If anyone knows of a resource like that and can share, that would be most appreciated!
Thanks in advance!
The reason I'm asking is that I have seen similar drawings without that line, so I just want to make sure I'm not going to plant a problem that someone else has to deal with down the line when they look at my prints :ROFLMAO:
Dear all, I am new to PLC and I need to understand some pneumatic blueprint. I did spend time to google the answer, but I could not find out...
4,293
Hello, I´m having a problem trying to program in Ladder. An output should be trigged by two possible contacts. Take a look on the printscreen...
166
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
197
Hi all, Writng a FB in ST on Beckhoff TC for a pulser which turns on and off on a cycle, is paused by turning bControlInput to FALSE, but resumes...
275
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
333
