I think you are asking if you can view ladder logic on the C-More. If so, as far as I know, the answer is no.
The best way to write a program is going to be with your PC using the free software. You will then download that completed program file to the Click PLC.
The C-More or any other HMI is used to view the states of addresses in the PLC. It cannot read the part of memory where the program logic is stored, but it can read and write to areas of memory affected by the program.
So, you can create a machine control program for the Click with the purposes of monitoring input devices, controlling output devices, and updating bits and values for display on the C-More.
And, you can write a program for the C-More to display information about the machine status in user friendly formats for the operator to utilize when running the machine. It can also change values and turn bits on which are being used by the Click program.
Think of the C-More as an infinitely variable array of push buttons and selector switches and pilot lights with dynamic legend plates. Think of the Click as an infinitely rewire-able panel full of relays, timers, and counters for turning on valves and motor starters, adjusting analog output signals and monitoring sensors.
I use the term infinitely loosely. You are limited by the instruction set in the PLC, the number of I/O points in the PLC, by the memory capacity of the PLC and HMI, and, by your imagination.
