Simple rslogix TON help
VICE5000
Oct 2013
IE
I am learning Rslogix on my own when free time is available at home and have created several simple programs. My question now, is how to change the value of a TON preset value in a program using inputs to increase and decrease the value. Any help is greatly appreciated.
The Preset of a timer - for example T4:10.PRE for timer T4:10 - can be the destination of any MOV or mathematical operations.
The instruction - ADD 1 T4:10.PRE T4:10.PRE - would add 1 to the current value of the preset.
Just make sure that you include a limiter to make sure that the preset cannot go negative.
LES Timer.PRE 0 MOV SomeSafeValue Timer.PRE.
Negative values in the preset will fault most processors.
Here are some simple RSLogix MOVE instructions to try with your simple RSLogix timer.
  • VICE5000 SIMPLE RSLOGIX TIMER.pdf
  • VICE5000 TIMER- LogixPro Version.ZIP
Good morning (EST), I am trying to implement the code below in on an S7-1200. It's barely half a dozen instructions, but I am stuck; I have not...
26
5,697
Hello, I have a modicon background where there is a "Pulse" function that accepts an input for the deisred pulse time length. I effectively...
2,061
Here is the rungs I have made for my school project: Basically I just press an associated Function Key (F1, F2, etc) on the PanelView to...
1,863
Hello everyone, thank you in advance for taking the time to read this post. All comments and advice are welcomed. I follow up on everybody in...
72
29,378
Hello everyone. I would like to thank anyone reading this post. I would appreciate any advice or thoughts on this program. I am a beginner. This...
28
9,553
