Simple S7 Indirect Addressing Question
Av8or1ab
Feb 2009
Mukilteo, Washington
I am trying to read a datablock using indirect addressing. My code is as follows
(int)DispX_DBNO = 151
(int)CurrScreen
OPN [#DispX_DBNO]
L DBB 4
T #CurrScreen
When I look at DB151.DBB4 the value is 5 which is correct. But using the code the value returned is a 0 :confused:. What simple mistake am I making?
Thanks 🤞🏻
That should work. You must be writing to DDB4 or #CurrScreen somewhere (or the GUI is writing to it). If you look at this online in STL, do you see a '5' in the accumulator?
You wiill probably have to add some traps throughout your code to see where the value is changing.
I know the problem is occurring because when I look at DB[#DispX_DBNO].DBB4 the value shown is 5, but when I load it into the accumulator while in online mode, it is loading a 0.
No, DispX_DBNO is in INT format right now, which I thought was represented in a WORD type as it takes 2 bytes. It is an int because I am doing some math to generate the number 151, because I am using the multiplexed addresses in the display for the tags.
I will try loading it through the call tree to find where the value is being changed.
I found the solution, and it was the word comment that you mentioned earlier. Instead of DBB it needed to be DBW as shown below. This must mean that the PLC stores data LittleEndian style.
OPN [#DispX_DBNO]
L DBW 4
T #CurrScreen
Thanks for the help!
i need simple way to understand the indirect addressing and pointer format with complex programing in step 7 what is the meaning of this...
1,764
Hello, I´m having a problem trying to program in Ladder. An output should be trigged by two possible contacts. Take a look on the printscreen...
120
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
177
Hi all, Writng a FB in ST on Beckhoff TC for a pulser which turns on and off on a cycle, is paused by turning bControlInput to FALSE, but resumes...
269
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
322
