simple tag server question
bulletin blues
Mar 2003
out there
223
Whats a tag server? At work I can monitor a mill on a pc set up in our control room. Allen Bradley PLC 5/40, control net and a dozen drives. Lotsa control stuff.
Sometimes I go to check out whats wrong with the mill but cant get the program to go online when the "tag server" is running.
First time, I closed the tag server and bingo, I can go online, but then I started thinking, hmmm, is our engineer gonna be going to this site saying, I keep droppin my Tag Server for no appearent reason?
So I have refrained from closing things that I know naught about and headed out to the old screwdriver on prox switch method of troubleshooting.
Im not technically proficient enough for a detailed answer, so...I'm just askin, roughly, whats this tag server doin? Seems to be a "not enough memory problem," should it be?
I'll talk to engineering if I ever get off the off shift.
Until then a little info would help. Thanx
Did it look anything like this ?
[attachment]
That's the database tag server for RSView32. It is using RSLinx to communicate with one or more controllers and serve the data it retrieves up to RSView32 stations in your system.
It shouldn't prevent you from going online with the PLC's using RSLogix 5, though, unless it's really hogging the bandwidth of the ControlNet. If that's the case, I would expect that Technical Support has already gotten a call saying "the tag server keeps shutting down all by itself".
Hi everyone, I am experiencing a similar problem with a RSView32 Application. I am migrating a PC under XP OS that runs a RSView32 project and is connected to 3 CPU's through a RSLinx Gateway. In this computer the "tagserver" window open everytime the project runs.
I installed this project in a W7 32 bits PC. The project starts and the OPC topics that we use for signal interchange with the 3 controllers are working. The only problem is that the "tagserver" program does not start. I am using RSView32 V7.6 and RSLinx Gateway.
What could be the reason? Do I need to make a special configuration for the tagserver?
Thanks in advance
I need to have an array tag that contains string data from a csv file. The csv file needs to be imported once per day. Is there any simple way to...
1,812
Hello Friends.... I am trying to read & write the PLC tags through VBA code but not getting correct syntax, i m using FTView SE 6.0 Your help will...
8,263
Hello and thanks to everyone who has made my Plc endeavors successful! I have recently upgraded to a 5/05 card, got a NT4 and a PanelView 300...
1,415
i would like to think i am a fairly capable fellow, but when i load the 'NEW TAG' dialog box... click '..' to search for data type and go to...
11,925
Hello, I´m having a problem trying to program in Ladder. An output should be trigged by two possible contacts. Take a look on the printscreen...
153
