carlisn,
You are making a fundamental mistake in how you are viewing programming inefficiencies.
It is not so much the number of rungs you execute, but more the execution of the instructions within those rungs that adds unnecessarily to the overall scan time.
Each rung added has an execution time of its own, Start Of Rung/End Of Rung (SOR/EOR), etc., and the total number of rungs in a program will add to the overall scan time. But this is usually negligible when compared to the time spent unnecessarily executing the same sequence of instructions more than once.
To use my Matrix view on it again...
Try not to view the logic before you as a physical construct. Where the perceived volume of logic, rung wise, automatically induces a sense of increased scan time. More, try to view the logic at the processor's execution level, where each instruction being executed is what is really increasing the scan time.
Your posted logic is a very good, and common example of where a programmer either does not realize, or realizes, but does not care, scan time wise, that they are re-executing the same sequence of instructions on multiple and consecutive rungs.
The first four instructions on each rung are an identical sequence of logic. This program is inefficiently executing this sequence three times. So that is twelve instructions being executed to give the same result when it can be done using less.
In fact, in this case, it will prove to you how actually adding another rung will improve the scan time, rather than add to it.
Insert a new rung above these three rungs and add the four offending instructions in sequence as they appear on the other rungs. Then add a new address bit to an OTE instruction at the end of this rung. What you will call this address is up to you, but it is a form of precondition to enable the logic on the original three rungs.
On the three rungs beneath, remove the first four instructions and insert an XIC instruction instead. Assign it the same address as the new OTE instruction.
Now when the program scan reaches the new rung, it executes the four conditional instructions and then executes the OTE instruction. This is now five instructions that have been executed.
On the first of the three original rungs it will then execute the new XIC instruction and if it evaluates true, the rest of the rung will carry on as before. Likewise, the other two rungs will do the same. This means you are now "inefficiently" executing one instruction three times, rather than the original four instructions.
So that is now eight instructions being executed instead of twelve, give or take the new rungs SOR/EOR execution time, which again is negligible when compared to the original setup.
The reason I said that the new XIC instruction is still being "inefficiently" executed three times is that it is possible to further consolidate the execution of the three rungs using parallel branching on a single rung. This is where a trade off between efficient execution and clearer programming is often decided. However, because the most inefficient aspect of the logic is now streamlined, you can start to consider further reducing the number of instructions executed by placing the new XIC instruction once on a single rung before branching out to the individual logic of the three original rungs. This removes the triple execution of the new XIC instruction, reducing the overall instruction execution from twelve to six.
It will now appear somewhat clearer than if the original logic was consolidated using branching on one rung. Whether one goes that far, or not, is up to them and whether the scan time saving is more important than the loss of clarity. It should not be too difficult to decipher this piece of logic though and good rung commenting always helps.
Lessons...
Increasing rung count can, at times, help to decrease the scan time. The consolidation method is used to reduce the number of instructions being executed and not the number of rungs being used. i.e. consolidation may involve increasing or decreasing the rung count.
Now that you know more, what else can be consolidated by going to one rung?
Regards,
George
