simulating 2-wire transmitters - AB ControlLogix
zlobe
Jan 2004
I am trying to use a Transmation Checkmate 100 to simulate 2-wire transmitters on a ControlLogix Analog Input card (1492-IF16) and using the interface module 1492-AIFM8-3. My RSLogix 5000 project has the module in Differential (integer) mode. We have the transmitter (which is battery powered and there for does not need an external power supply) connected to a channel, with 1 lead on IN0 and the other lead on IN1 and jumpered to RTN. We are expecting to see integer values returned to the PLC when we input current, but the value does not increase. Is there anybody familiar with this equipment who can let me know if there are more connections that need to be made, software config to be done, or if this sort of simulation can even be done with this calibrator/simulator? Thanks for your help.
The default input mode for the 1756-IF16 module is 0-10 volts; did you remember to configure it for 0-20 mA in RSLogix 5000 ?
I don't have the 1492 AIFM interface wiring system manual on-hand... did you try wiring this up directly to a wiring arm on the module ?
Hi Do any of you have some experience with simulating a servo drive with Emulate3D? I have tried to research and thinking of a way to do it...
1,496
Hello all, Trying to simulate with TIA V15 because the hardware won't be ready for a few weeks. I have the PLC simulated and running. Can go...
12,563
1)Is there a way to simulate Analog input instead of a instrument in the simulator mode to test the software? like plcsim in Siemens you are...
2,119
Hi Everyone, As part of FAT testing, I am looking to test the PLC logic by simulating the analog inputs. Is there any way to feed analog input...
2,852
I am trying to test my PLC program but I find the PLCSim of TIA portal insufficient: you can only run one sequence at a time. I am trying to test...
6,024
