Simulating PID loops
tomhelliwell
Feb 2008
Sheffield
25
Hello there, I have to do a presentation at college to show the successful simulation of a PID loop. such as a graph.
Is it possible to simulate a PID loop without a connection to a PLC? Im using Intouch 10.0
thanks
Tom
You couldn't sim it in WW with no connection to a PLC because that's where the loop data will be. I have a VB program for simulating a PID loop if you want it.
There is no system as such this is theory. I can manually choose a setpoint/s and with the tuning parameters i have worked out, prove that the parameters are correct.
You should have said this is for a control theory class.
Your parameters are correct for what kind of system? There are zero, one, two, three, four .. pole systems. The are non-integrating ( type 0 ) and integrating ( type 1 ) systems. When there are two or more poles it is possible to have complex pairs ( underdamped ), critically damped and over damped poles.
Each type of system has a different formula for calculating the PID gains.
Knowing what your plant is like is the first step.
I would try scilab which is free at www.scilab.org.
Hi Do any of you have some experience with simulating a servo drive with Emulate3D? I have tried to research and thinking of a way to do it...
1,492
Hello all, Trying to simulate with TIA V15 because the hardware won't be ready for a few weeks. I have the PLC simulated and running. Can go...
12,558
1)Is there a way to simulate Analog input instead of a instrument in the simulator mode to test the software? like plcsim in Siemens you are...
2,114
Hi Everyone, As part of FAT testing, I am looking to test the PLC logic by simulating the analog inputs. Is there any way to feed analog input...
2,851
I am trying to test my PLC program but I find the PLCSim of TIA portal insufficient: you can only run one sequence at a time. I am trying to test...
6,018
