Simultaneous multiple wifi connections
neilm
Feb 2019
Jackman
28
Hello everyone,
I am an Automation Engineer in a manufacturing facility. There are multiple LANs here. Are there any recommended wifi adapters to attach to your laptop to connect to multiple wifi networks at once?
Regards,
NeilM
Following - I'd love to find a single USB-Wifi adapter that supports multiple connections. I have used multiples of the single USB-WIFI adapters with success; the inexpensive ones from Amazon, no specific brand. Found this link The 9 Best Wi-Fi USB Adapters of 2019 in a google search. The TRENDnet TEW-809UB is of interest.
I do not advise connecting to multiple wifi networks at the same time.
you could create a circular loop and bog the network down to the point it shuts down with traffic.
you can create multiple wifi connection points on your laptop and connect to the specific one you want.
we have multiple networks here over the entire plant. each has its own purpose. cell phone, guest, plant, and several others.
each has their own password.
james
Follow-up with James
Thanks James and jstolaruk.
To James, in such a scenario, will a simple disconnection of the laptop to LAN be sufficient to bring the network back to operational levels or any other procedures/software required?
To jstolaruk,
In order to use these external wifi USB adapters with the laptop's internal wifi card, is it necessary to use a software like Speedify?
I'm super new to the Controls world. This is my first controls job and i never went to school or have a background. I was just a technician that...
21
4,070
This is arguably a Windows question, but it must be applicable to a lot of people. When we go to the shop floor to connect to a machine network...
2,433
Wonderware Intouch, Kepware timing issue with "simultaneous" writing of many tags I have an Intouch application coupled with Kepware that is...
17
7,220
Hello! I have a control panel with two hard-wired push buttons. One button to switching on, and another one to switching off. And I have an HMI...
2,055
I have and AB ML1500 LSP (DF1 only) and a AB C400 hmi (Ethernet), will the DIGI IAP allow the 2 to communicate and allow RSLinx/RSLogix access at...
1,251
