Sinamics G150 with startdrive V15.1
Apache
Dec 2014
Finland
Hi!
Has anyone any experience with Sinamics G150 comissioning with TIA startdrive 15.1. As far as I know, it should be possible with version 15.1.
How G150 comissioning differs from G120?
Is there similar wizard, or is more manual work?
I could not find any manual about this issue..
G130/G150 is like setting up an S120
They use drivecliq.
G120 doesn't have drivecliq
No similar wizard
I suggest you play around with an offline project in Startdrive and build it from stratch to get the idea
If you've ever used Starter with either of these you already have an idea
Hi Dear i have A30042 alarm on sinamics G150 and i know that must to set P0251=0. but in parameter list in all access level on AOP30 and in...
1,907
AB controllogix, Molex profibus SST card and Siemens MicroMaster 440 & Sinamics G150 Hi, I have project which use AB Controllogix as PLC and...
4,963
I got a problem with siemens sinamics where the drive generate an alarm without fault code. The alarm appeard as NO CONNECTION TO DRIVE and MASTER...
2,742
1,804
Hello sameone have Beckhoff PLC Siemens Sinamics V90 configuration example?
108
