AB controllogix, Molex profibus SST card and Siemens MicroMaster 440 & Sinamics G150
wilsonzhu
Jan 2008
vancouver
278
Hi, I have project which use AB Controllogix as PLC and Molex SST-PB3-CLX_RLL as profibus card, and Siemens Micromaster 440 and Sinamics G150 as VFD drives. I am new to siemens. I download Starter and .GSD files for two drives. I would like to use Standard telegram 1, PZD-2/2 for G150, it can be set by starter commissioning tools, but I do not know how to set PPO 3 for MicroMaster 440 with Starter? Another question is what number resprent 100% speed in speed setpoing PZD and Actual speed PZD? Thanks,
I found in the manual 4000Hex for 100% speed. How to set PPO 3 telegram into MicroMaster 440?
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
86
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
215
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
197
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
233
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
96
