single phase to three phase VFD
jdkasper
May 2002
Kansas
40
I need a 115vac 1-ph to 230 vac 3-ph Variable freq. drive that will handle a 1 hp motor. I can possibly get by with 3/4 hp if necessary. Who carries such a beast in the US. This will be running a 24" web rewinder and the motor will sport an 18:1 inline reducer so the motor will never see full load. Any suggestions?
BTalbot
Thanks for the reply. I can't believe I didn't think of Mitsubishi considering this place is loaded with it.
Thanks again, that is exactly what I need.
With referance to my latest post w.r.t. Mitsubishi VFD,
What benefit of using single pahse input to VFD I mean 120 V or 230 V, expect unavailablity of 3 phase supply?
That's exactly it. Their benefit is that you CAN use them when you only have a single-phase supply.
-Eric
Dear all, My machine will connect to three phases power 208V, but some of my electronics in the machine need single phase 110V . Where I can...
3,019
Gents: When the primary of a 480v 3ph by 240v 1ph transformer is connected across two legs of a three-phase source, is it not true that the 240v...
26
7,396
Hello we have a single phase pump 115/230 ac volts and the shop we want to use it in has three phase 230 volt system, but no 230 single phase...
27
11,866
what are the advantages for three phase power supply than single phase power supply ?? i have a machine contain electronic cards and three phase...
11,423
What would happen if you ran a 60Hz Single Phase Motor on 50Hz supply?
537
