single phase-two speed motor, two capacitors and one relay
kalabdel
Feb 2015
Ontario
1,108
Hello everyone,
I ran into this 230 single phase two speed motor with two capacitors and a relay (see picture) and have a few questions:
The relay is mounted on the motor, in a casing similar to a capacitor's, what is it for?
Is it a potential relay?
Capacitors, both for staring, one for Low speed and one for high speed, or one of them is run capacitor.
Is there a way to get info (literature) on the motor?
looks like it's a standard two speed motor with a start and run cap. the X would be where the relay would cut the start cap out once it got up to speed. usually theres a centrifugal switch for this purpose. but some use things like a "Sinpac" switch, which is a solid state relay for dropping single phase capacitors out of circuit once at speed/voltage
difference in this drawing is there will be another run capacitor always in circuit, typically to improve the efficiency of it.
this is a better picture of how its probably set up
just without the high speed winding. to make it high speed, add another point of contact between the windings to reduce the number of poles (or use another winding altogether). and then a contactor to switch between the two.
That's great, than you gentlemen.
I had a quick look at the rear of the motor and there was no centrifugal switch so I figure this is likely to be a potential switch but the data sheet I I found just called a power relay.
So I understand then that the run capacitor connects to the main winding regardless of the number pole pairs connected, same capacitor for both speeds.
Cheers
Repeat Question - Maybe to our UK friends, especially. I need variable speed control of single phase blower motors, for an OEM I work for. I...
3,624
Does anybody have any experience/suggestions for variable speed control of single phase motors? My application is: Control up to 4 - 1/2hp fans...
20
6,709
Dear MEmbers, There have any method to control speed single phase motor?. I'm try sourcing using VFD, but VFD only can using for 3 phase motor...
3,584
I Brought One Wet Grinder From India To Use At Saudi Arabia. It Fixed With Single Phase Motor 230 Volts /50 Hz, It Is Using For Grind The Rice,all...
20
6,935
What would happen if you ran a 60Hz Single Phase Motor on 50Hz supply?
533
