Sinking/Sourcing Input Outputs
Here's a simple rule to help remember "Sinking / Sourcing".
VCC=Power Source
In a very simple form, relative to VCC, think of the transistor as either coming before or after the device.
If the transistor is connected between VCC and the device, it is sourcing current.
If the transistor is connected between the device and ground, it is sinking current.
Good morning all. I have never seen this done but I want to ask if it is possible. On an AB 1766-L32BWA, can you have some of the inputs wired as...
2,365
I have a client who has installed a control system which was designed offshore (ASIA), and uses a power system common to the Asian market. The DC...
1,933
I spending a lot of time for searching on this subject "sinking and sourcing input", but there are not simple answer. I want to add stop/start...
7,093
O
what is a sinking or sourcing input/output means?
4,107
Hi there, I have a 2 wire npn sensor. For example in this diagram: I'm guessing i should connect it to a PLC dc sourcing input as such? Would...
5,220
