Sinumeric 802D maximum rpm setting
Utco
Dec 2007
Pune
42
Hi, I am requiring to increase more speed (more than 3000rpm) of my servo. Can anybody tell me the maximum supporting rpm of Sinumeric 802D instead of increasing my gear ratio? And if speed increased then what will be the effect on servo motor?
Hi everybody. Anybody can Help me? I am facing a problem in a roll grinding M/C (RGM), which was installed by Romanian. In this system they used...
2,373
hi all we are using a cnc lathe scoda sut 140 nc which is operated with sinumerik 840 c version 4 suddenly the machine turned the langauge to...
2,332
Hello Everbody, I want to use Sinümeric 802D sl controller for my project. But I need to help. I will use Sinümeric 802D sl for cutting table...
2,151
What is a reference for the maximum jitter on the cpu of a controller for motion control? We have done some tests on an IPC with Codesys...
1,039
Hi PLCs.net! I was curious: How many axis can a B&R APC910 control? Is there a hard limit like certain AB controllers? I'm new to B&R, so would...
387
