Sinumerik 810d/840d
naishadgosai
Aug 2005
surat,gujarat
39
I Want Upload Or Download From A Cnc Machine.
I Hv A Pg ( Field Pg With S7 Plc Softwares Like Simatic Manager).
Which Additional Software & Cable ,i Need To Load Into Pg To Do This.
I've you've got a PG, it should have an MPI/DP port. Just get a regular Profibus cable, connect one end to the MPI/DP port on the PG, and the other end to X122 on the NCU.
Open up the Set PG/PC Interface and set the interface for MPI, 187.5kbps. If you open the Accessible Nodes, the PLC should show up as address 13 or 2, depending on how yours is configured. THere may be a couple more addresses to (6,1,...). Just open blocks folders until you find the one thats got the PLC blocks into it. Once you've got the address sorted out, you can upload and download.
Dear All, I have CNC Siemens Sinumerik 810D machine with all NC module and HMI station with MMC103 WIN95 i want to upgrade this Windows XP.So...
2,317
I have a Sinumerik 828D control panel and its for a CNC machine, the problem is that it gives an error state 700027 tool turret state :S4...
114
Hello: I am at a customer's factory in which a 20+ year machine from Germany is occasionally showing Alarm 120201. I was asked to diagnose a...
1,053
Greetings everyone, I have an MMC 103 NCU 573.3 (6fc5357-0bb33-0ae3) to work with my Sinumerik 840D, but the problem is that I can't start it...
1,021
Hello,guys. We have one 840Dsl milling machine and there are B_11, B12, B_13, B14 planetary (fixtures) on it. They can rotate 360 degree and...
1,723
