SINUMERIK 840Dsl, LEDs on MCP are freezing
wendaiyu
Jun 2014
toronto
87
Hi, guys, we have a 840Dsl milling machine. Since one week ago, there is a small issue on it: LEDs on MCP are freezing after pressing Reset (PO) on the HMI. We have to shut down the main power and power up, then MCP works well.
When LEDs were freeing, we checked the I/Os on MCP via PLC. They were all functional. E.g. I0.0 is for “JOG” on MCP and Q0.0 is for its LED. I0.3 for “AUTO” and Q0.3 for its LED. When we pressed “JOG” button, I0.0 and Q0.0 are both 1. And when we pressed “AUTO”, I0.3 and Q0.3 are both ON. But the LEDs still remain the same as the last status before we press Reset (PO) on the HMI.
We replaced a new MCP, but the same problem.
We found that for normal MCP, if it has communication failure with PLC, all LEDs are flashing. But in our case, even the HMI showed us communication failed, the LEDs were still freezing.
We checked I/Os and changed MCP, so we think the communication cable or 24V power may be defective.
Could you give us a hand to figure it out ?
Thanks a lot.
Hello,guys. We have one 840Dsl milling machine and there are B_11, B12, B_13, B14 planetary (fixtures) on it. They can rotate 360 degree and...
1,724
I have a Sinumerik 828D control panel and its for a CNC machine, the problem is that it gives an error state 700027 tool turret state :S4...
141
Hello: I am at a customer's factory in which a 20+ year machine from Germany is occasionally showing Alarm 120201. I was asked to diagnose a...
1,061
Greetings everyone, I have an MMC 103 NCU 573.3 (6fc5357-0bb33-0ae3) to work with my Sinumerik 840D, but the problem is that I can't start it...
1,027
Dear All, I have CNC Siemens Sinumerik 810D machine with all NC module and HMI station with MMC103 WIN95 i want to upgrade this Windows XP.So...
2,329
