SLC-150 C convert program?
aczlan
Apr 2021
Upstate NY
We have 3 SLC-150s that we are using, we would like to create a print for them and diagram the program so when we get approval we can replace them with something newer and so if something goes wrong we know where to look.
I was able to connect to all the PLCs and read the program, then save it as a .100 file, but I would like to open it in something a little easier to read than the DOS software.
I see some threads talking about converting the files to .txt or PDF, is there software available to do that?
Aaron Z
DOS (Dosbox for W10 and W7) with PCIS is the only thing that will work with the PLC's you can print a PDF after you open the software (I think)
Ah, that makes sense, I didn't realize that I could save the ladder programming to text files by using the print function (F3) after loading them.
I used Virtual PC 2007 and MSDos 6.22. I was able to save the text files to the DOS pc, then copy them off to my computer.
Thank you!
Aaron Z
You can use a VM called DOSBOX, its free and will run on W7 or 10, thats what I use
You can find everything you need here https://www.plccable.com/allen-bradley-plc-slc-100-150-usb-1745-pcc-cable/
The manual is there incase you have issues converting the program also videos on how to set it up
And welcome to PLCTalk!
Thanks, I had found those links and downloaded the manual.
I went with the Virtual PC as then it will work on any computer with XP or higher (not just my laptop) and it wont risk getting messed up by Windows Update or something changing.
I actually use dosbox for some of my kids games at home (they love playing Oregon Trail and Amazon Trail).
Aaron Z
How can I get a schematic for it? I am unable to communicate to it using PCIS with a 486 PC and suspect the SLC150 to be faulty (found in a junk...
3,112
HELP! I've been searching & searching for the software to run my SLC150 PLC for DOS 6.22 and for some reason, every link I have found for it -...
1,154
Hi, I have an old SLC 150 processor that is throwing up a CPU Fault light. I have an EEprom program chip for it, but I can't get it to load up...
2,338
Hello, I am completely new to PLC's (and forums) and have been tasked to repair/upgrade a conveyor system at my college. It currently has an Allen...
2,690
1,777
