slc 5\01 connect with pc (1747-pic a )
abajamal
Oct 2009
jeddah
hi .
my probli i connect the lap top with 1747-pic a to slc 5\01
but came to me ( no commnucation )
what i do in this case .:)
If that doesn't help, you'll have to give us some more clues.
What is your operating system, including service pack?
What kind of problems are you having?
What exactly are you doing?
etc...
The more clues you give us, the better the chance that we can help you. We can't help with "it doesn't work"
etc...
thank you
iuse dos system rockwall software 1987-1996(6200 slc500 progrmming dev @ doc sw ).
message timeots - loss of communication .
i used ( personel computer interface converter)1747-pic a with lap top
best regards,
Has it ever worked before? Or is this a first attempt at using this computer/setup to access a SLC?
Wow! DOS system and 6200 programming software. That brings back old headaches! It was hard to get it to connect when new. I can imagine now it would be almost impossible.
First you need a real, true, serial port on your laptop computer, or a way to simulate one that the 6200 software will accept.
I use DosBox with PCIS and it works very good... I also use a USB port, not sure if it will work with 6200
Hi All, I have a SLC 5/04 plc that I need to communicate to - however we don't have any null modem rs232 cables on site. I am very new to Allen...
2,633
Hi guys, Working on one of my client's systems with SLC processors, earlier today she called me and said she was having comms errors, had a solid...
2,046
I recently inherited some 5/04 CPUs and a single 5/02 CPU that I need to pull the programs from. The 5/04 CPUs didn't pose any problems. I...
3,054
Hello All, I’m trying to connect some SLC 5/03 and SLC 5/04 processors to RXLinx but am unable to see the connection to the processor in the...
2,308
Hey everyone! It has been a while since I have had an issue to post about but here I am back to gather some knowledge from yall. SLC5/05 talks to...
18
4,971
