I have a SLC 5/03 setup I've been programming on the side to control Christmas lights, and just noticed an anomaly with this 5/03 - when I put it in Program mode to do a Sys Comms download (up to now I've done almost all programming using online edits) the outputs that are on at the time STAY ON when in program mode, throughout the download, & remain on until the unit is placed back in Run - then they respond like they should.
I went online with another 5/03 in a test rack & it shuts off all outputs as soon as it goes into Program, like I expected. I compared every setting between the 2 setups & the only setting different is "Index Across Data Files S:2/3" is No on the test rack & Yes on the Christmas lights system; and if I change bit S:2/3 on either to toggle the state it immediately toggles back to what it was. I even checked a 5/05 in another test rack & it says No & turns off all outputs in Program. It shows as a checkbox under Controller Properties, but can not be changed online, and I doubt this would cause the outputs to stay on in program mode. (EDIT: I just changed the Test 5/03 offline to Enable Indexing Across Data Files & downloaded it, it's now Yes & still turns off all outputs in Program mode.)
Both 5/03's are 1747-L552C, 32K, OS501 Ser C. Using RSLogix500 ver9.00 (CPR9). Zipped Xmas file attached.
Is there some other setting causing this or maybe a bad PLC? When I got more time (later) I'm thinking of swapping the 5/03's out & reprogramming them to see if it's in my program or in the 5/03 itself.
