SLC 5/03 Running with no free memory
seaston_65
Nov 2008
Ontario
47
Hello everyone,
I've just got a quick question here.
On the floor we've got a machine with a SLC 5/03 that currently has 3 instruction words left in memory.
The machine has a few small bugs that could be fixed with programming changes, but that would require a CPU upgrade. The machine is old and will be phased out in the near future.
The operators/supervisors can live with the small bugs, but I'm wondering if there are any issues with running a CPU that full.
I understand that if something came up that required a rewrite (like more automation) we'ld have to upgrade, but other than that is there a problem with leaving the machine as is?
Thanks for your help in advance.
-Shawn
The only issue I know of is that you cannot perform online editing with so little memory left.
Can you post the .rss file? It might be possible to streamline the code and free up some space...
I know about the online edits, that's what drew my attention to how little memory was left.
I can't post the file. sorry guys. I do know that the program isn't as efficient as it could be, it's just justifing the time required to make the changes.
You may want to buy a used CPU from eBay... 5/03's are cheap and if you have a 1747-L531 you would just need a L532, if you have a L532 you would need to go to a 5/04, but still cheap
Do you have any spares CPU's in the plant? it would be a good idea to have a spare for your other PLC's, I used to keep a 1747-L543 as a spare... that way if we had a failure I knew that I had a back up for the SLC's
Only justification I can come up with re-writing.. or upgrading.. is
How much would it cost to not do it? Is it worth the risk of a small memory leak (poor programming) overwriting the last remaining space, or trying an online edit by accident.. or any other possible reason.
If the time to rewrite or replace is 5x less than the "down time".. let sleeping dogs lie.. till they bite you in the arse.. :) especially if you plan on an upgrade in the near future. or as genius stated.. buy a non warrenty cheap replacement.
Dear , problem : Adding and configuring analog input module 1794-IE8 to existing running system SLC 5/03 through 1747-BSN (DH485) System: - 2...
3,771
Morning everyone, I know this sounds trivial (but I haven't done it in a long time) but what is the best way to add a PLC card to a running...
5,039
Hey guys I'm messing with an AB system, SLC 5/03 OS302 and I'm wondering if I can download my offline logic changes while the PLC is running...
5,160
Hi.. I want to run four difference recipe on SLC-5/04 and recipe selection on four difference screen on PV1000. How to make difference recipe...
2,440
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
97
