SLC 5/04 error - No Nodes on Network
chrisculler
Jul 2014
Sumner, WA
Hi everybody,
I have a green coffee storage and transfer system that's giving me an error. Power was off for a couple minutes, then when I turned it back on, the Panelview 550 (2711-B5A8) shows an error of "688 No active nodes found on network". The CPU has a constant FLT on, and also will also flash BATT, FORCE, DH+, RS-232 indicators, but NOT the RUN indicator.
Turning the key to clear the fault hasn't worked, nor has repeated power cycling.
To be honest, I'm very unfamiliar with any sort of PLC programming, and this system predates almost all of us here, so please forgive me if I ask basic questions.
Thanks in advance!!
The bad news is that the CPU is toast.
When the FLT stays solid red and the other LEDs flash, that's a major hardware self-test failure during boot-up.
If it has an EEPROM module in the socket inside (be sure to turn off power before removing the CPU) you might be able to perform a reset by removing the battery and shorting the Vdd/GND solder pads on the back of the CPU for a minute.
If you have a backup of the SLC-5/04 program and can buy a new CPU from North Coast Electric, you can be up and running tomorrow.
If you need onsite help, I'd recommend calling Taurus Power & Controls or Concept Systems.
Hello, I have a forming machine that has a SLC 5/02 and Panelview 300 terminal. Unfortunately, the machine was seldom used and the battery quietly...
4,496
I've got an old Heald grinder that's been set up with one of these. It's worked flawlessly for quite some time, we powered it up this morning and...
21,065
I’ve got an interesting issue with an SLC Message instruction which won’t clear error message 38h without cycling the key switch. I have 2 SLCs...
929
Hi, We are having issues with an intermittent Major error code 21h. The plc can be running for varying amounts of time before faulting anything...
1,885
Hi, I have an old SLC 150 processor that is throwing up a CPU Fault light. I have an EEprom program chip for it, but I can't get it to load up...
2,338
