SLC 5/04 programming cable
Coulombboy
Jan 2012
Makati City
70
Hello guys. Got Slc5/04 with 9pin d shell port in it. Have cheked some manuals and this port is an RS 232. I want to ask if I could use a generic usb-rs232 converter to have the PLC programmed? Thanks in advance.
Should not be a problem, I think you'll need a gender changer. I hooked up last week with mine and didn't have a problem. WHen you setup the RSLinx , first look in your windows control panel for the comport your adapter is using. CHoose the SLC-Ch0 /micro.. driver.
Yes, you can use most of these USB/RS232 adapters. However, some have had issues in particular with the Auto-Configure option in RSLinx. I usually tell people to go with a name brand adapter. Many forum members prefer Keyspan.
Keep in mind that you will still need to use a null modem serial cable in addition to the adapter. All the USB adapter is doing is giving your PC a serial port. The null modem cable is still necessary.
OG
i have a slc 5/02, but i'm not sure wich software to use (i have both rslogix 500 and 5000) but the main problem is that i dont have the cable, i...
5,727
Does anyone know the correct AB cable I need to connect a laptop serial port to an SLC 5/04 processor programming port, specifically the DIN...
13,339
Need help to get the cable to connect to Programming TERM 8 pins to DB-9 female for DH-485 ( NI PCMCIA-485 ) card with laptop interface. The 8...
18
18,170
I am just finishing up my project, which was my first experience with PLCs. I thank everyone that has helped me work through the RIO and analog...
2,979
Hello, I've taken on yet another basket case old machine running an 7 slot SLC 5/03 PLC.... I have run into a situation where I see the same 4...
5,624
