SLC 5/05 Ethernet connections
sparky mark
Jul 2008
Lititz, PA
I have two SLC 5/05's communicating over Ethernet.
under channel 1 status I see the following:
First PLC:
total = 5 , incoming = 4, outgoing = 1, maximum allowed = 0.
second PLC:
total = 5, incoming = 4, outgoing = 1, maximum allowed = 48.
Is any of this a problem? Is the max allowed of zero a problem?
Seems to communicate OK over an Ethernet cable. Have had problems with them communicating over RF Ethernet.
My guess is that the "Maximum Allowed" value in the one that reads zero is a firmware bug that doesn't read the status registers correctly.
Are the two controllers the same firmware revision ?
With low connection counts like that, connection capacity is unlikely to be the root issue. Dropped connections because of dropped packets may be; you'll have to investigate more carefully about what's happening to the connection counts during runtime with the RF system.
First PLC:
second PLC:
I assume you're using messaging instructions? How often are these being executed? If you're sending over radio modems then you may be exceeding the bandwidth available on the radio channel.
Calculate how many bytes per second you're likely sending and compare this to the performance specs of the radio (remembering there is some overhead for the TCP/IP packets)
I have just started with a new company and they want me to look at some logic in a automated system using a SLC 5/05 processor, 3 input cards and...
14,177
I know how connections are created, but how are they released? Problem SLC: 1741-L551B OS 501, FRN 8 Ethernet Daughterboard Series 2, FRN 59 I...
15,102
Hello all! I have some machines that run an SLC 5/03 and occasionally a fault is generated. Recent Example: A power supply wasn't screwed in...
424
Hello, I've got a project where I need to get information from two ABB ACS880 VFDs onto the plant operator's screen (or alternatively, onto...
23
2,610
We are replacing a piece of machinery with a newer version. The new assembly has 5 TCs which are closer by far to the operator station than the...
2,259
