slc 5/05 firmware upgrade
5james77
Oct 2012
michigan
Hello all! I am trying to upgrade the firmware on a 1747-L553. I can get it back to factory. But I can't get my computer to talk to it over the Ethernet? Does anyone have an idea what I'm doing wrong? After I reset to factory settings then I have to download to it. But when I do I loose my rs232 connection and I cant find it using the ether net. What am I doing wrong or missing?
Do you have a fault on the processor itself? Also you are talking about using the ethernet driver under RSlinx and not ethernet-IP correct?
I just know with those processors you have to use the ethernet driver and not the ethernet-IP otherwise you get faults and communication errors mid-town load. So you could be getting an error while your downloading your new firmware. Or downloading job you were putting back in after your factory reset. I've only been messing with PLC's for less than a year. So if your already aware of these issues and it's definitely not that I apologize. I just figured I would mention it for sake of knowledge to anyone else reading.
We're you able to talk to it via ethernet before the upgrade or reset. If you reset it I'm assuming that means the IP address has changed so therefore whatever Ur laptops IP address needs to match. Except the last octet of course
Well then try using RSlinx with rs232 and configure the ethernet IP address to match your laptops IP address. All except the last number. Those have to be different
And your right my phone brought up the wrong processor. I apologize for that confusion. There are numerous settings you have to change when you click on the controller properties under RSlinx. For example check box Bootp enable needs a check
I just purchased a 1747-OS302 firmware upgrade kit (Ser A, Rev A, FRN 11) from my local distributor. However, when I go through the set-up...
3,943
Greetings all! I have a SLC 5/05 OS501 Series C FRN 9. I would like to Update this to Firmware FRN 10. Does anyone know where to get the Control...
4,405
Hi, I have 1747-L532E (OS302 C FRN 11) and RSLOGIX 500 ver 8.40. In RSLogix I can only choose FRN 10 for processor type. How to upgrade firmware...
1,965
Hi, I have just flashed an SLC5/05 Cat No. 1747-L551 FRN8 with the latest available firmware from Rockwell using ControlFlash and now the CPU is...
1,779
Dear All, I need to upload program from slc 500 fixed controller (1747-L40C), series "B" and FRN "6"and to download the program to another PLC...
23
7,299
