SLC 5/05 "program not compatible with processor
dclark
Sep 2014
Texas
After establishing comm's with the 5/05 processor via RSlinx classic, I tried to download a simple XIC and OTE program and the processor responded with "programe not compatible with processor". Has anyone experienced this and could you help me resolve this?
Welcome to the forum.
In RSloigx500 double click on the controller properties in the project tree on the left hand side of your screen. Make sure you have the correct type processor selected for your program.
Let's get the obvious out of the way first.....
Are you using RSLogix 500 and if so, what version is it? The RSLogix 5 software looks identical but is "not compatible".
When you attempt to download, are you going to the Comms menu and then selecting System Comms and then clicking on the specific SLC to download to or are you using another method?
OG
Ok...the processor version is L552B 32k rev.c I have tried download from pull down menu (top left next to Force etc..) and from Comms menu. my processor is correct under controller properties. For I/O configuration is correct after "read I/O configuration". I just wrote another simple one rung XIC and OTE program and it worked. Fault light off Run light on, all is good. I saved the project and wrote another identical rung but addressed 1 bit different on both, Tried to download ( both ways and same thing "program not compatible with processor". The I quit that program and tried to download the first one that did work and now...same thing..."program not compatible with processor". Any Thoughts?
Ok, from the Comms menu, do NOT select Download and most certainly do NOT select it from the Online toolbar (where Force status is displayed). Select System Comms. This will bring up a window similar to the RSLinx Who Active window. Select your RSLinx driver on the left side of the window and then click on the controller on the right hand side. Then click the Download button.
OG
Ok...First attempt to download resulted in the following" fault code 0001h.. default program loaded due to NVRAM error..a corrupt crc was detected
Cannot go online from default processor..you must perform download
second attempt same... third attempt ok. Any thoughts?
I'm trying to consolidate several slc500's to one 5069 L306er. SLC 500 program sizes are giving in words. And compact Logix controllers are sized...
844
Has anyone taken a SLC500 program and converted it to an Automation Direct Click PLC program? I searched but didn't find anything.
1,783
Hi Everyone, I was hoping someone can help me with this request. Unfortunately, I do not have the RSLogix software to open the old SLC programs...
1,491
Hello everyone, I am migrating a program from STL to SCL via S7-1200 portal, I would like you to help me by converting these lines of code...
1,647
Hi, I have a SLC 5/04 processor, model 1747-L541 that had the backup battery fail a few weeks ago because we didn't see the BAT light on it in...
4,827
