SLC 503 using net eni; to panel view 600 plus
kenr305
Jul 2008
Miami
I had a problem come up today. I connected the net eni to the
slc 503, I can see, program and monitor the processor using​
RS Linx and logix.
I can program the panel view 600plus thru the switch, when I run theruntime simulation it works perfectly on my computer, it sees the tags and provides the information as requested.
When I download the program and try to run the application on the panel view it downloads fine and the screens show up as expected but the information from the plc is not there (gauges and bar graphsand numerical displays)
I can't seem to find the problem. Any suggestions on where to look?
You have not copied your offline communciation link to the ONLINE communication setup in Rslinx Enterprise.
COMMON ERROR.
That is why your PC simulation works, because you have specified your path correctly.....
Friday I located the problem
There is a check box that must be checked in the download program that says overwrite communications.
Somehow that box had become unchecked.
Once I checked it everything went to working perfectly.
I want to download SLC 503 using DH485 port but I did not have 1784-PCMK card and cable. I could not use com port of processor because it is used...
2,983
Probably a silly question and asked a hundred times already, but i tried to do some searching here and couldn't find this question. I have 502's...
3,020
Tried to communicate with the CPU and then replaced the Battery because the battery was dead. Does this mean that because the battery is dead and...
2,334
Hello, I'm a electrician who is furthering my education and learning to be a programer , I have a Dell laptop running windows 7 with rs logics pro...
22
6,353
Hi everyone. I am new here in this page. This is my first post. I hope to receive the best suggestions and tips wanting also to collaborate...
2,738
