Well I never heard of this APS before so being a noobie I just assumed it was going to be standard RS LOGIX 500 being it was a SLC. Why would it be so easy right?Is you goal just for programming access, or do you intend to put this thing on your ethernet network? If the latter, I think Digi makes a device that will do it for access via remote RSLinx stations or HMI's. If the machine needs a HMI and full time data collection, you could go that route with a G3 or other HMI which supports protocol conversion.
Any ways my intention is to add to the program a very simple addition. This is an machine that cuts 7/8 copper tubing at various lengths. Longest beinb 84". This uncoiler has a air brake with a single valve. I simple wanted to use a LS on the cutting machine to trigger a TON timer,to then energized this brake and then release. At the most 4 rungs. Then download back into the SLC. We only have RS LOGIX 500 Starter. Well we just ordered it so it will be here in afew weeks.
But after seeing the PLC program a curve ball was thrown my way by it being this APS programming I never heard of. I dont know what to do now because I really dont want to get into having to rewrite the program as I a still a noobie Tech,nott a PLC programmer. But I also dont want to appear to have put my foot in my mouth.
