SLC data files to Excel?
Steve Kemp
Nov 2003
122
Hi all. I have 30 "N" files (250 words each) that I'd like to view in an intelligible format. Is there any way of copying the data directly from RSLogix into say, Excel? Thanks, Steve.
Do a search here as well as in your RS Linx help file for 'DDE/OPC'. It will help you to understand a lot.
Ken Moore said:
On line or off line?
What flavor of RSLinx do you have?
The answer to this question makes a huge difference in the approach.
I'll assume you really do mean copying from RSLogix and not reading from the PLC, so I'll go with the simplest answer first: offline viewing.
Save the entire PLC proram file as a library file. Open the library file in MSWord or notepad. Find the data files. Cut and paste to a blank word document and edit it to CSV format. Then save as a .csv file and open in Excel.
If this is not what you need then please get back to us all.
I'm looking to replace an AB PanelView 600 2711-K6C2 HMI with a C-more EA9-T10WCL. The PLC in the system is a SLC 5/03, which is staying. I...
1,249
I trying to adress to data file x and word x with my full access page on my Panel View 600. It's work well, but when a entry a incorrect word...
5,874
In a slc 500 plc I am trying to move data with out using a lot of moves. I want to move data from n7:1 to n7:2 and data that was in n7:2 to n7:3...
1,368
Hi. I'm working with a SLC 5/05 but I have no experience with it. I've been tasked with trying to figure out if it is possible to directly modify...
1,079
Long time member, first time poster. Last night our plants wireless network died, shutting the whole plant down. As a result, I have been tasked...
1,539
