SLC devicenet
eastkodakguy
May 2002
Fayetteville, Arkansas
96
I am having some trouble with devicenet in the SLC processor, and I am now a little confused. first off I keep hearing about this M1 and M0 files which i can address in the plc but i cant look at a data table, and what is this data for. also when i configured the devicenet in the I/O configuration it gave me 32 words of input and 32 words of output.which is suppose to happen What I dont get is how do I know what input or output bit is what. Here is an example of what I am doing. SLC 5/04 1747dnet module, talking to a bulletin 160 drive. I have the inputs mapped in rsnetworx. All I want to do is set a bit for the drive to change. I have looked through some manuals and still cant seem to get an idea of this
Thanks in aDvance
Dallas
Remain calm. Breathe deeply.
If you have only one reference manual, make it the 1747-SDN Installation Instructions.
http://www.ab.com/manuals/io/1747/1747-in058c-en-p.pdf
There is an I/O map in this slim volume that should make the Discrete I/O table (32 words) and the Module I/O table (150 words) clear to you. It also includes a concise reference to I/O Word 0, the Command/Status Word in the Discrete Input and Output tables.
If you post your *.DNT file (zipped for the purpose, of course) I'm sure that all can be explained in even more detail.
Customer has a circa 2004 SLC-500 PLC. Fieldbus is a 1747-SDN DeviceNet scanner. Customer has SLC-500 file (.rss) with no comments. Has no *.dnt...
571
Machine has existing DN devices that are connected to SLC 5/04. All communication is working fine now. Supplier wants to remove some DN devices...
858
I'm having a strange issue where the operator can input a desired speed in 0-110%, and the scaling will correctly translate that in Hertz to the...
2,330
Good Afternoon , We had to replace a Powerflex 70 2 HP with a 3 HP. These drives are on Devicenet . Once installed and transferring with...
3,987
Hello, As some of you may have seen in another thread I have a deviceNet network of valves and realised that no one saved the network...
2,209
