lostcontrol
We recently had a SLC504 fault with Error code 857h. Now, from the help files, this means that it was in slot 8, with fault 57, which is:
I have a suspicion that this has happened before recently, but did not have a copy of the error log, as thje fault was cleared with the key switch before we were aware of it.
And the error has been recovered, but is this a symptom of the module failing? What would be the best pland of attack to negate this happening again?A specialty I/O module has not responded to a lock shared memory command withing the required time limit. This error is recoverable.
