SLC 504 Download failed, Communication Errors!
Pukeko
Dec 2018
Christchurch
As part of an upgrade I am working with 7 different SLC programs. I had the first program in a test controller in my office running and communications all healthy. I went to download the second program which has all the same processor and comms configurations and got "Download failed, Communication Errors" once it got to the "writing executable files" part of the process. After messing with trying to get that to work for a bit, I went back to the first program and got the same error with that program, even though it had been fine. I've been on the knowledge base and have tried deleting harmony files and updating rslinx as suggested by them. I can download a blank project to the controller and go online without any trouble.
At a total loss as to what the problem is and hoping someone here might know.
Welcome to the PLCTalk Forum community !
What communication driver are you using ? Any chance there's a real communication error occurring, like with a loose wire or missing termination resistor ?
Hi Ken,
I'm going through the backplane of an L7 and out of a DH+ card. I can download and go online with a blank project so pretty sure that the wiring is all ok.
I don't think that downloading a small program rules out noise or other organic communication errors, because the probability of a checksum error goes up with the size of the data packets. A default program with no routines might get through where an ordinary application program won't.
But passing through a ControlLogix backplane and a 1756-DHRIO also raises the possibility of data mis-handling there. In particulary I remember a bug where just one confirmation code wouldn't be processed by the DHRIO so the "write to EEPROM" function on an SLC-5/04 would appear to fail. Obviously this isn't the same function, but maybe there's something similar with a data block size limit, or a buffer availability error for a large download.
If you can, connect directly to the SLC-5/04 via DH+ or DF1 and try your download that way.
Hi, thank you. I've been out of the office so only read replies this morning. I will try connecting directly and see how that goes. The reason for going through the L7 is because of replicating what the customer has on site. It's just strange that the one program I did download before this error occurred also won't download now.
Has anyone ever seen this before. I have a SLC 504 running a very small program and it would seem the TON wouldn't start counting using the...
24
4,706
Probably a silly question and asked a hundred times already, but i tried to do some searching here and couldn't find this question. I have 502's...
3,006
I have a SLC504 in the field that is communicating DH+ to several other SLC504 and the RS232 port is communicating to a panel view plus 1000. I...
1,275
Hi, I am having an issue on one of my station. It won't communicate after the power shutdown. If we cycle the power it is communicating , but I...
1,463
If I have a 1746-OA8 and have used all the outputs, can I upgrade it to a 1746-OW16 without any issues? I realize one is a relay output card and...
1,746
