SLC 504 issue with TON
The other test is do you have another SLC CPU you could download the program to and see if that one screws up the timer.
Then put a test program in this CPU to see what it does with various timers.
EDIT: Do the other timers with 0.01 timebases's work?
The PDF has almost all of the other timers using the 0.01 time base, so I think the answer to that is yes.
I saw that but had to ask.
Sometimes the stupidest question is the one that figures out the root problem.
And when working with operators in stamping plants I have had to ask some stupid questions, and then ask why he/she didn't tell me that 2 hours ago when I first got here.
Yes all other timers work fine.
When we are able to take it down i'm going to try a download and add some extra Bits and Floats and see if that helps, then i will replace PLC. Regardless if the download does anything i will replace PLC either way because I can't trust it now. Think if this was on something important. A delay timer for a shutdown or something.... No one would ever believe that the timer just didn't work.
LOL
Thanks everyone for helping me prove my sanity.
... No one would ever believe that the timer just didn't work. .
I have a SLC 5/03 sitting on my desk, covered with red glitter hot melt glue so I never use it in a project, that when you put it in Program, or fault it out purposely, it 'forgets' to turn off any of the outputs that were on that scan.
Now (not running) it will never turn the pumps, blowers, conveyors, valves, etc. off until it kills every person on this planet and no one is left to generate electricity for it to keep powered up.
Refusing to run one timer is paltry compared to this.
LOL
Thats pretty bad.
Probably a silly question and asked a hundred times already, but i tried to do some searching here and couldn't find this question. I have 502's...
3,006
I have a SLC504 in the field that is communicating DH+ to several other SLC504 and the RS232 port is communicating to a panel view plus 1000. I...
1,275
As part of an upgrade I am working with 7 different SLC programs. I had the first program in a test controller in my office running and...
2,510
Hi, I am having an issue on one of my station. It won't communicate after the power shutdown. If we cycle the power it is communicating , but I...
1,461
If I have a 1746-OA8 and have used all the outputs, can I upgrade it to a 1746-OW16 without any issues? I realize one is a relay output card and...
1,746
