Slc Redundancy - Ab
gururaj
Sep 2005
Dubai
There are 4 SLCs..,
SLC 1&2 are Primary and secondary at one end, and SLC 3&4 are
Primary and secondary at other end. All SLCs are communicating through Ethernet network. If SLC1 is Primary and SLC2 is secondary, and if SLC1 looses communication with SLC 3&4, then I would like to switch SLC 2 as primary and SLC1 to slave. How it is done through software ??
Thanks,
Guru
Assuming the hardware doesn't already support redundacy, you are implementing it in an ad-hoc fashion, and you've made the proper electrical connections, I would first consider watchdog timers.
Each PLC has a watchdog timer that would be assigned to the remaining PLCs in your communication networks. Each PLC sends a message to the other PLCs that clears its assigned watchdog timer in the receiving PLC. If a watchdog timer times out then each PLC will assume that the PLC assigned to that timer is no longer functioning.
The algorithm/schedule (whatever you want to call it) will have to be thought out by you. Create a decision matrix listing all of the possible scenarios and what each PLC should do for each condition. The decision matrix should also consider a break in the communications network but all PLCs still active. Then implement it in ladder logic.
Something to chew on and get started with.
Hello, I have a ControlLogix redundant controller being set up. The program reads a value from a remote site which hosts a SLC PLC. Rockwell...
98
HI, i want to know about slc redundancy system , hardware configuration as well as software programming .any body can help me regards, souvik
1,773
How can I configure a redundant slc 5/04 system to scan and backup IOs on DH+ while, at the same time, capable of connecting to 4 other devices...
1,460
In a redundant slc 5/04 system, consisting of 2 slc 504 and a 1747-ASB, is it feasible to connect the redundant system to a an existing DH+...
2,092
hi i am using two slc 5/03 processor each having its own backup scanner,to this bsn is connected a 2 rio one for input and the other for output...
2,243
