Slc05/??
Dallyn Czar
Aug 2013
BC
I currently have a slc05/01 but its pretty limited as to what i can do. I know i need a slc5/03 or better to run an analog input in class 3 mode if i am correct but i was trying to create a floating point file i believe like and f8: or what not and i dont even have that option. Now i dont wanna spend the big bucks to upgrade to and 05/04 or better but have a couple options on a SLC05/03 at a reasonable price does anyone know if i can make a float file on an 03? If so im saving about a thousand bucks.
Go to processor configuration and see what OS you've got. OS300 doesn't support Floating point. OS301 and OS302 do.
Good Luck,
(8{)} :) .)
Yosi
Hi
The best thing to do is make a copy of your project and then change the processor in that project to the one you are thinking of getting. Then you will be sure.
Donnchadh
Look at Micrologix 1400, that supports Floating point.
Depending on I/O you may be ahead of the game. $$$
Hi guys, I'm trying to retrieve the scan list from a network in a SLC 05 and when I try to go online in RSNetworx, the "OK" button is grayed out...
1,546
Good afternoon, i have been reading some postings and wanted some clarification from some of the AB experts on this site. First question, i take...
2,504
Hello, I've a question, I want to work in a project where there are 10 MicroLogix 1500, 10 SLC 505 and 10 SLC 503, and I want to monitor 600...
2,376
hey on slc05/04 can i use thr cable 1761 cbl-pm02?? or how else can i program with it
1,538
Can i download slc 500 L-543 ,5/04 CPU64K MEM TO SLC 500,L552C 5/05CPU 32 K MEM.
1,873
