SLC500 FW upgrade problem
pw3
Sep 2007
MICHIGAN
96
Hello-
In using the 1747-DU501 kit to upgrade some spare 5/05 processors I am running into an issue where ControlFlash is not reading in all of the processor info, including the catalog number, which is needed to perform the procedure.
In fact, it is only finding the Vendor info.
The kit was originally purchased back when we still had WinXP laptops, and it worked fine. We're now running Win7, and have already tried it in "compatibility mode" for XP-SP2 with no luck.
Anyone run into this before?
Thanks--PW
Hi! I have an almost 20 year old AB SLC 500 PLC (fixed i/o, 40 points). It uses a 1747-AIC DH-485 Link Coupler over a 100 meter communication...
1,176
I had a 1747-L542 32k processor that was only showing "3 instruction words left" for Memory Left. We swapped this out with a 1747-L543 64k...
2,550
Hello All, I have been assigned to upgrade the automation system of a District Heating plant. At present the system employs two SLC500 PLCs. The...
3,147
I need to get the latest firmware for a new SLC505 Rev C processor. I have done a lot of ControlLogix firmware upgrades, but never on the SLC...
5,330
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
261
