SLC500 to MicroLogix 1000 using DH+/DF1 Converter
SLC_USER
Oct 2005
Charlotte
Hello All,
This if my first time to the forum. Glad I found the site. It looks very helpful.
I'm trying to add a MicroLogix 1000 to a DH+ network with a SLC5/04 and a couple of PV 1000's. I'm considering using a DH+ to DF1 interface module, a DL3500 from DataLink Technologies. The module manufacturer assures his device will work but I'm uncertain of how I can write to the MicroLogix from the SlC.
What instruction do I use to write from my SLC5/04 to the MicroLogix? I looked at the MSG instruction and the only target device selections available are 500CPU, 485CIP and PLC5. Anyone have any idea which one I need to select or is there some other instruction or setup that I should use instead?
Thanks in advance for any help!
The MicroLogix and SLC-500 communication codes are almost identical. You can send messages to your MicroLogix 1000 via the DL3500 as though the MicroLogix was an SLC-5/04.
Select the "500CPU" target type in the MSG instruction configuration.
Thanks for the reply,
The system has been installed and is working beautifully. The information you provided was exactly correct.
Hi everyone, though plc is not related to my job, I'm interested in learing Allen Bradley SLC500. I installed program to my ML1000 and fixed...
2,431
Does anyone have experience with changing the channel 0 mode to user remotely using RS232 communications? I have checked the mode change enable...
4,220
Ok, i have micrologix and slc 500/04 processor i want to connect them to a server and comunicate with them and modify programs so if i get an...
1,664
What is involved software wise to connect a slc500 and a micrologix 1500 together? I just wish to get some practice with setup before inserting a...
2,664
I was wondering, is there any specific rhyme or reason to the ability to do online editing? Or is just some feature specific to the type of...
8,799
